It is currently Mon Aug 18, 2025 6:22 pm
 Post subject: Making Wood Purfling
PostPosted: Tue May 13, 2014 8:23 am
First name: EddieLee
Last Name: Brown
I want to make purfling for the soundboard that has a center strip of Brazilian Cherry about 75 mil wide with a strip of black on either side. I plan to resaw the Brazilian Cherry and sand to the correct thickness, glue a sheet of 10 mil fiber board (from LMII) on each side, then cut 100 mil strips from that.
Is there are better approach? Any Tips? idunno
_____________
EddieLee
 Post subject: Re: Making Wood Purfling
PostPosted: Tue May 13, 2014 8:30 am
First name: Al
Last Name: Peebels
City: Johnston City
State: Il
Zip/Postal Code: 62951
That's the way i do it. I don't use fiberboard though. I use contrasting veneer.
These users thanked the author Peebs for the post: EddieLee (Tue May 13, 2014 9:19 am)
PostPosted: Tue May 13, 2014 8:37 am
First name: David
Last Name: LaPlante
Gluing them all together is fine for a back strip etc. but they will be much harder to bend for top purfling.
I usually glue marquetries (in your case the cherry) one side only to the bordering veneer (black fiber) this will help hold all together.
Cut separate strips for the other side and assemble on the guitar.
These users thanked the author David LaPlante for the post: EddieLee (Tue May 13, 2014 9:19 am)
PostPosted: Tue May 13, 2014 9:21 am
Last Name: Brown
Thanks, Al I did find any black veneer large enough for the job. Where do you get yours?
_____________
EddieLee
PostPosted: Tue May 13, 2014 9:41 am
Last Name: Russell
State: Michigan USA
EddieLee,
You may want to have a look at this thread:
http://luthiersforum.com/forum/viewtopic.php?f=10117&t=42804
This is how I cut mine for my parlor which has 17 layer Maple/Walnut/Maple... etc... perfling and rosette. Because there were so many strips I had to be very accurate. I got all the strips within .002" tolerances. The first part of that thread is the scraper jig I used to get the tolerances so tight. If you scroll down the page I also posted some pictures of the mini table saw I made for my Dremel to cut the strips. It worked really well.
If you have not seen it, here is the link to pictures of the finished guitar.
http://luthiersforum.com/forum/viewtopic.php?f=10101&t=43368
As for the black perfling, I have been looking into it and I think the best way to do them is using Maple with alcohol black dye. I plan on cutting the strips first and then soaking in the dye and then scrape them to thickness. I think they will have to soak for a few hours to absorb the dye deep enough. I have not tried it yet so I don't really know how well the Maple will take up the dye. If that doesn't work then I am planning on using Spruce.
I have a whole bundle of the fiber stuff... I wouldn't use it after I got it because it pretty much sucks. The test strips I did I didn't like the way it fuzzed up when scraping or sanding. I may use it one day on something I don't care too much about but for something really nice.... I'll make my own.
Hope this helps,
Bob
These users thanked the author RusRob for the post: EddieLee (Wed May 14, 2014 1:17 pm)
PostPosted: Wed May 14, 2014 1:18 pm
Last Name: Brown
Thanks Bob. I did see both treads but some how did not connect the 2. I may have to look in to your little table saw.
_____________
EddieLee
